Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
15421 - 15440 of 15505 Posts
Most Known Unknown
Discussion Starter · #15,421 ·
Started working on installing the DRP sump I bought from Lyle a long while ago..
I went ahead and installed new FASS filters and I’ll install the CAT filter tomorrow since I’ll need to pull the fender liner.
Pretty straight forward, you’ll need a 3.25” hole saw and buckets or containers to hold your fuel.... lucky me I got antsy and drained 3/8 of a tank :)
Any clean container I had I filled and poured it into the tank for the old Cummins, the rest I’ll save for later.
It’s a TEXAS thing..
Chose the rear of the tank
And here we go!
Most Known Unknown
Discussion Starter · #15,422 ·
Lucky me I had a swivel fitting for half inch line!
It worked perfectly because I wanted the return port to point down so I could easily run the line to the sump without kinking it so close to the frame. I put a street elbow for the tank feed port.
Most Known Unknown
Discussion Starter · #15,423 ·
Still waiting..
Finally what seemed like a lifetime later I cut the hole, cleaned it up, and pulled any shavings towards the center, and deemed it ready to rock.
Kitty litter helps!
It’s idiot proof
It’s grooved a way that it only works ONE way
Most Known Unknown
Discussion Starter · #15,425 · (Edited)
Done deal for now
Tomorrow I’ll get some loom to protect the long sections, cut the cover for the sump to sit flush inside, and change the CAT filter up front and add some fuel..
And I’ll have to find a hose repair kit again because I somehow lost the one I bought last weekend :(
That way I can fix the filler neck!
I mean, this could work... keep the fuel cool.
It might drag on a few of the speed bumps while mall crawling
Reactions: jwcgmc1985
Looks good Jeff I used some spiral hydraulic hose protection on my line coming off my sump. Got it from NC Machinery shop.
Here are a couple of pics for reference
Still looks like new and last a longtime with no worries.
Sent from my VS988 using Tapatalk
Most Known Unknown
Discussion Starter · #15,428 ·
Heck yeah!
You never wanted to put your cover back on?
I ended up with 3/4” loom today
And you know this Maaaan!!
Most Known Unknown
Discussion Starter · #15,429 ·
Finished up the install today and even replaced the CAT filter up front.
Ended up using 3/4” loom to add protection from rubbing though I used three spaced out zip ties to hold the lines together above the cover.
Cut the cover and realized I was a little off (eye balled it) and trimmed some more and scoffed the edges with a flap disc.
Removed the liner and changed out the CAT filter up front, and went ahead and used my new hose repair kit (middle size piece from the kit) and tied the filler neck hoses together.
I like how it doesn’t hang down past the cover much at all and the lines are concealed between cover and tank.
Heck yeah!
Nope dont need it since it is a pavement princess. Lol
Most Known Unknown
Discussion Starter · #15,434 · (Edited)
I’ll need to clean up my edges a little on the cover, I’ve noticed a few things :(
But the concealing of the hoses was my objective, but making such a big hole wasn’t.... but it’ll be fine!
Sump cover plate FTW!
Most Known Unknown
Discussion Starter · #15,436 ·
Throwback TUESDAY!
Does anyone happen to have the old cable that iirc the mini maxx used? The cable that fit the OBD2 but converted over to HDMI?
I am trying to buy/borrow one so I can hook my old Bully Dog GT Tuner up to my Gasser to see what I can change (mainly tire size) before I try another route to correct the speedometer..
Finding one seems to be a lost cause and eBay failed me which is weird..
Post a pic of what it looks like?
I found one on eBay Jeff...
Most Known Unknown
Discussion Starter · #15,440 ·
Heck no!
I need it on the free fiddy or close to it :)
I just need one to verify:
A. Does the truck have a canned tune on it
B. Does the old tuner I have it have the ability to turn off the DOD feature and change tire size to correct the Speedo
That or beg a friend and see if his equipment can disable the TPMS, correct the speedometer, and possibly disable the DOD feature
