Here's a write-up I did on
www.reddit.com/r/diesel for a fellow inmate. It has some good points concerning the injector swap.
Nothing horrible just very involved to get down to the injectors. It's approximately a $3000-$5000 repair if you pay a shop to do it.
You have to buy the replacement injectors which can run a few grand. Usually around $200ea.
You have to buy replacement fuel line seals and FICM seals.
You have to buy the injector removal tool. This makes it very very easy and ensures you don't pull a cup out. Twist the injectors to loosen them before using the tool to pop them out.
You have to drain your coolant to remove lines and insure against removing an injector cup.
You'll probably also need a handful of tools. I had to buy several hundred dollars for of stuff to get the job done and I have a fairly stocked weekend warrior's garage.
The upper valve covers are glued on from the factory. Use a slide hammer on the lift points and it pops right off. Make sure you have all your bolts out.... I did not and got to buy a new valve cover.
The worst part is dealing with all the bolts at the back of the bank near the firewall on the driver's side. They are all sandwiched in their pretty badly. I removed the heatshield which game me enough room to use a 5mm Allen wrench. Other said you can take a Allen socket and grind it down to get it to fit in there. I spent most of my time Sunday dealing with this area.
I started Thursday night, worked all day Sunday, drove 3 hours on Monday to pickup a new valve cover for $36, and worked all day Tuesday.
It is every bit of a 12-24 hour job. Just tons and tons of bolts to turn. I learned a ton about the truck in the process. Was very frustrating at times, but the way the truck runs now made it all worth while.
Smooth. As. Silk.
Oh! One more thing. Purging the fuel system will take some time. Lots of air to get rid of. Just purge like you would if you put a new Fuel Filter on. Crank it a few times. Purge again. Keep doing that until no more air bubbles come out and then it should crank over. After each initial crank you'll get a big air bubble when you go to purge that wasn't their the previous time.
Things to watch for:
If the fuel return banjo bolts aren't torqued to the specific spec they will leak fuel into the head and down into the block (into your oil). Watch oil level religiously for a few days after the job. If you're making oil then you've got a leak.
Clean valve cover around where the injector electrical wires go through to avoid dumping dirt into the head when you remove it. Ask me how I know.
Take pictures and label as much as possible. Put bolt groupings in ziplock bags or trays.
Soak your injector lines (feed lines) in CLR water mixture overnight. Other how-tos say 6 hours but that wasn't long enough for me. 12-24 hours did the trick much better.
Get fender covers. You will be sitting in the engine bay or hanging over it for a very long time.
Having a second pair of hands to retrieve things helps immensely.
