1 - 20 of 22 Posts
i notices today my truck is kinda loping at idle not bad like a lope idle but u can kinda hear one. i was wondering if i should be worried or is it normal i guess i have never really payed attention? any advice would be appreciated thanks
I wouldn't worry just yet. Wait and see if you start to get smoke. Could be a sign of the fuel pressure regulator going bad, or it could be a sign of injectors acting funny (stuck open or something). Do you run any additive in the fuel?
No everyonece in a while I do but havnt latly. Should I put some injector cleaner in and run some additive or no? How much does a fuel pressure regulator run about?
I believe they run about 500... 700 if installed by a dealer, but the FPR is not always the case, it could be this shitty winter blend fuel we are just getting out of our pumps, run some additive and give it a while
What additive do u guys prefer?
Where is rawlin by the way? And ya just give it time to see if any more signs come up. Run 2 cycle oil or Power Service Diesel Kleen the gray bottle
Ohw much of the bottle should I put in when I fill up of the diesel kleen
^^^ yea I agree, I use the PS Diesel kleen grey bottle
Half the bottle
i use 2 stroke oil... works just fine
What kind of 2 stroke oil does it matter and how much of it ?
Chevy dmax89 rawlins is over in wyoming and it gets pretty damn cold here so hopefully I got some bad fuel
Well with the freezing temps and the winter fuel blend its gonna run different than 90 degree weather. Dont worry about it, just keep using additives. These LB7 injectors really need it. Run it even in summer..
blue bottle from walmart... make sure its the twc-3 or tcw-3. u can buy the quart or the 16oz bottles. i get the 16 oz bottles and dump the entire thing in there
Discussion Starter · #16 ·
i put in the diesel kleen the gray bottle today so i will see how that does
XBoxLive: RenegadeDuramax
When was the last time you changed the fuel filter?
Discussion Starter · #18 ·
it hasnt been that long ago maybe like december january sometime in there
Any luck with the Diesel Kleen?
I'd try changing the fuel filter. I change mine every 5k, and sometimes sooner. Fuel quality is getting worse, no matter where you buy it. I add a can of sea foam every now and then, and a small bottle of 2 stroke oil every oil change, but I don't use any additives regularly. I'm still on factory injectors. I've owned the truck since it was new and it has 171,000 miles on it.
Sometimes my truck has a lopey idle when the filter needs changing. It's not getting the fuel through the filter at idle, but it does when under throttle because the fuel pump is able to pull harder.
In most vehicles, the pump pushes fuel. In ours, it pulls fuel. I'd put money on the fuel filter being the problem.
Just my opinion.
1 - 20 of 22 Posts
