i have a c4500 kodiak that will start and run for about a minute or so and then just die like u turned the key off . I know its not fuel related like air in the system this is a power problem, when it dies and try to restart it just cranks but if u turn the key off and wait afew seconds and try again it will start and die a minute later i also have codes for u0073 and p0883 and light in the dash come on 30sec before it dies one is a coolant tank sym and the other is a red incomplete circle with an x through it if somebody has any idea please help
saw what you did there
U0073 Control Module Communication Bus Off.
P0883. TCM Power Input Signal High.
weird.
fixed it found out the lights in the dash were kinda the problem on the kodiaks they have an auto shutdown with the coolant res. replaced res and lights went out and truck runs ok
