13081 - 13100 of 13177 Posts
The new ones pre auto shift all do. My 2014 Columbia dose and the clutch switch is going bad. Sometimes I have to push the clutch several times to get it to start. There are very few manual trucks left in our yard that don't have clutch switches on them.
Sent from my SM-A505U using Tapatalk
Reactions: kowclub173
I was going to say the reason it probably isnt to common is due to that. I mean even a 2018 579 I drove didn't have one. It makes sense though, because if that switch goes open circuit in most applications you'll only lose high idle, cruise control, and engine/jake brake.
Sent from my SM-N950U using Tapatalk
So this Happened a few weeks ago, to another driver in the company....Kinda has me worried about driving refers down the road at night.
1080804
1080805
Refer fire. pre emmision equipment.
I would think it smoke moving, but flames would not errupt until stopped.
Kinda like putting a leaf blower on a bonfire.... Gets raging hot, but little to no smoke or flames.
Finally! Wheels on!
What followed you home? Get anything for your trade?
What you talking about?
Nothing was traded. Bought the semi yesterday.
We need to know more about the truck😑
2007 KW W900, 2005 C15 with 890K original miles on it, one annoying thing is that it has a 10 speed with 3.36 rears in it. So the plan will be to pull the 18 speed out of the freightliner and install a cut off with 3.70s and full lockers.
10 speeds work just fine with modern engines.
Reactions: nashguy207
Your not rebuilding the freightliner?...I been searching truck paper. They are asking quite a bit for them old trucks.
