L5p bulletins, recalls and updated calibrations
271K views 177 replies 72 participants last post by  Foghorn
#1 · (Edited)
i do work for a GM dealership as a diesel tech so when I come across any updated calibrations or fixes for issues I will let everyone know.
If you DO NOT UNDERSTAND what is being said in these bulletins I wont answer them, this is purely for information on the everything GM is doing with the l5p.
#PIE0401: Engineering Information - Malfunction Indicator Lamp Illuminated with One or More Glow Plug Control DTCs Set - (Mar 9, 2017)
Subject: Engineering Information – Malfunction Indicator Lamp Illuminated with One or More Glow Plug Control DTCs Set
Attention: Proceed with this EI ONLY if the customer has commented about this concern AND the PIE number is listed in the Global Warranty Management / Investigate History link (GWM/IVH). If the customer has not commented about this condition or the EI does not show in GWM/IVH, disregard the PI and proceed with diagnostics found in published service information. THIS IS NOT A RECALL — refer to the latest version of Service Bulletin 04-00-89-053 for more details on the use of Engineering Information bulletins.
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
2017
L5P
All
GMC
Sierra
2017
2017
L5P
All
Involved Region or Country
North America
Additional Options (RPO)
Equipped with ENGINE-DIESEL, 8 CYL, 6.6L, DI, V8, TURBO, DURAMAX (RPO L5P)
Condition
Important: If the customer did not bring their vehicle in for this concern, DO NOT proceed with this EI.
Some customers may comment may comment on a malfunction indicator lamp illuminated.
During diagnosis a technician may find one or more of the following DTCs set:
•P06C5
•P06C6
•P06C7
•P06C8
•P06C9
•P06CA
•P06CB
•P06CC
•P066A
•P066C
•P066E
•P067A
•P067C
•P067E
•P068C
•P068E
•P0671
•P0672
•P0673
•P0674
P0675
•P0676
•P0677
•P0678
•P1337
•P1338
•P133A
•P133B
•P133C
•P133D
•P133E
•P133F
Cause
GM Engineering is attempting to determine the root cause of the above condition. Engineering has a need to gather information on vehicles PRIOR to repair that may exhibit this condition. As a result, this information will be used to "root cause" the customer's concern and develop/validate a field fix.
Correction
If you encounter a vehicle with the above concern, follow SI procedures for any of the DTCs other than P06C5-C or P1337-F.
If any of the DTCs listed in this section are set, clear the codes and relearn the glow plugs. Refer to Glow Plug Learn in SI.
After the glow plug learn procedure has been completed, let the vehicle sit a minimum of 4 hours before starting.
After 4 hours, start the vehicle and verify if any MIL and any DTCs are set.
Contact the engineer listed below to report findings and for further instructions.
Contact Information
Engineer Name
Phone
Please include the following information if leaving a message:
– Technician name
– Dealer name and phone number
– Complete VIN and repair order (R.O) number
On the repair order, document the date and time the call was placed (even if the engineer was not reached).
If engineering is unable to return the call within one hour, proceed with diagnosis and repair based on information found in SI.
Warranty Information
If engineer was contacted or required information was provided, use:
Labor Operation
Description
Labor Time
4081568*
0.5 hr
*This is a unique Labor Operation for Bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
You are about to leave the website of General Motors and view the content of an external website. That website is not owned or controlled by, or affiliated with General Motors or its subsidiaries, and it is subject to its separate terms and conditions and other agreements, as well as its privacy policies. General Motors cannot be held responsible for the content of external websites.OKCancelWarning© 2017 General Motors. All rights reserved.
#PIP5481: Check Engine Light On With DTC P026A and a Snow Plow Installed - (Mar 2, 2017)
Subject: Check Engine Light On With DTC P026A and a Snow Plow Installed
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
All
All
6.6 L5P
All
GMC
Sierra
2017
All
All
6.6 L5P
All
North America
Additional RPO/s:
6.6 L5P
Condition
Some customers may comment on a Service Engine Soon Light / Check Engine Light on.
Technician may find DTC P026A and a snow plow installed.
Cause
Under Investigation.
Correction
Please refer to the owner’s manual under Adding a Snow Plow or Similar Equipment (In Service Information it will be Document ID 4501631).
It states:
Caution: Do not exceed 72 km/h (45 mph) with a snow plow mounted to the vehicle. The vehicle could overheat and be damaged.
However, GM engineering is aware of this concern and is investigating.
This Preliminary Information will be updated when further information is available.
Version
1
Modified
#PIP5480: Hesitation, Bump or Chuggle - (Mar 2, 2017)
Subject: Hesitation, Bump or Chuggle
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
All
All
6.6 L5P
All
GMC
Sierra
2017
All
All
6.6 L5P
All
North America
Additional RPO/s:
6.6 L5P
Condition
Customer concern may be of a hesitation, bump, chuggle, jerk or a feeling of harshness under the following conditions:
 1. Vehicle speed in the range of 25-45 mph.
 2. Light accelerator pedal tip-in or tip-out maneuver.
 3. Transmission in 3rd gear.
Cause
Correction
GM Engineering is aware of this concern and is working on a resolution.
Version
1
Modified
Reactions: alk8778 and X25
#4 ·
#17-NA-051: High Oil Pressure during Initial Start of Vehicle - (Feb 23, 2017)
Subject: High Oil Pressure during Initial Start of Vehicle
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
2018
L5P
All
GMC
Sierra
2017
2018
L5P
All
North America and Israel
Additional Options (RPOs)
Equipped with Diesel 6.6L Engine (RPO L5P)
Condition
Some customers may comment on high oil pressure or that the oil pressure is "pegged" high during the initial start up of the vehicle.
Cause
When first starting the engine with cold oil, the oil pressure can be up to 100 psi or 690 kPa (full range of oil pressure gauge) at idle conditions. This is normal with cold oil and internal relief valves in the engine will be active. As the engine oil temperature rises, the idle oil pressure will reduce.
Correction
This is considered a normal condition and no repairs should be performed.
Parts Information
No parts should be replaced for this condition.
Customer Information
Please communicate to the customer this condition is a normal characteristic of their vehicle. It will not impact the designed performance or reliability of the vehicle. Please share this information with the customer, including a copy of this bulletin.
Version
1
Modified
#PIP5468: Check Engine Light On with DTCs P0101, P0299, P11CC, P11DC, P2002 and / or P20EE set. - (Feb 10, 2017)
Subject: Check Engine Light On with DTCs P0101, P0299, P11CC, P11DC, P2002 and / or P20EE set.
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado 2WD
2017
All
All
6.6 L5P
All
Chevrolet
Silverado 4WD
2017
All
All
6.6 L5P
All
GMC
Sierra 2WD
2017
All
All
6.6 L5P
All
GMC
Sierra 4WD
2017
All
All
6.6 L5P
All
North America
Additional RPO/s:
6.6 L5P
Condition
Some customers may comment on a Service Engine Soon Light / Check Engine Light on. Upon inspection technicians may find DTCs P0101, P0299, P11CC, P11DC, P2002 and / or P20EE set.
Cause
These DTCs may be the result of loose connections of the charged air cooler ductwork.
Correction
If any combination of DTCs P0101, P0299, P11CC, P11DC, P2002 or P20EE are set; check for loose charged air cooler ductwork at the turbocharger outlet pipe, the charged air cooler inlet pipe, the charged air cooler outlet pipe and the connection at the throttle body.
Please note that a static visual inspection may not reveal that the connection is not adequate and that it is most likely to occur during engine roll or brake torque.
Object ID: 4697543Click here for detailed picture of the image.
Picture of a non-secured connection between the charged air cooler pipe and the throttle body.
#PIP5469: Check Engine Light On With DTC P10D1 - (Feb 7, 2017)
Subject: Check Engine Light On With DTC P10D1
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
All
All
6.6 L5P
All
GMC
Sierra
2017
All
All
6.6 L5P
All
North America
Additional RPO/s:
6.6 L5P
Condition
Some customers may comment on a Service Engine Soon Light / Check Engine Light that occurred once and did not persist beyond one key cycle.
Cause
Upon inspection technicians will find DTC P10D1 set.
Correction
Complete the current SI diagnostic for any trouble codes or symptoms found.
If the diagnostics are inconclusive and this is the first occurrence of this condition on this vehicle, the MIL can be cleared and the vehicle returned to the customer.
Version
1
Modified
#7 ·
#PIP5470: Check Engine Light On With DTC P054F - (Feb 7, 2017)
Subject:
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
All
All
6.6 L5P
All
GMC
Sierra
2017
All
All
6.6 L5P
All
North America
Additional RPO/s:
6.6 L5P
Condition
Cause
Upon inspection technicians will find DTC P054F set..
Correction
Complete the current SI diagnostic for any trouble codes or symptoms found. If the DTC P054F is no longer active and this is the first occurrence of this condition on the vehicle, the MIL can be cleared. GM Engineering is aware of this concern and is working on a resolution.
Version
1
Modified
#PIE0395: Engineering Information - Malfunction Indicator Lamp Illuminated with DTC P22FE Set - (Feb 3, 2017)
Subject: Engineering Information – Malfunction Indicator Lamp Illuminated with DTC P22FE Set
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
2017
L5P
All
GMC
Sierra
2017
2017
L5P
All
North America
Equipped with ENGINE-DIESEL, 8 CYL, 6.6L (RPO L5P)
Condition
Some customers may comment on a malfunction indicator lamp illuminated.
During diagnosis a technician may notice DTC P22FE set.
Cause
Correction
If you encounter a vehicle with the above concern, contact the engineer listed below.
Important: Do not clear any DTCs.
– Technician name
Labor Operation
Description
Labor Time
8480588*
0.3 hr
Version
1
Modified
#PIP5466: Check Engine Light On With DTCs P1016 and / or P1017 - (Jan 30, 2017)
Subject: Check Engine Light On With DTCs P1016 and / or P1017
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
All
All
6.6 L5P
All
GMC
Sierra
All
All
6.6 L5P
All
North America
Additional RPO/s:
6.6 L5P
Condition
Some customers may comment on a “Service Emission System” warning in the DIC that occurred once and did not persist beyond one key cycle. The malfunction indicator lamp (MIL) would also be illuminated. Upon inspection technicians will find DTCs P1016 and / or P1017 in history.
Cause
This may be the result of the Diesel Exhaust fluid (DEF) emission system detecting an intermittent serial data communication fault between the DEF quality sensor that is internal to the DEF tank and the DEF tank controller mounted on the DEF tank. The actual cause of the intermittent serial data communication fault is under investigation but has been shown to occur typically only once.
Correction
Complete the current SI diagnostic for any trouble codes or symptoms found. If the “Service Emission System” warning andP1017 DTC are no longer active and this is the first occurrence of this condition on the vehicle the MIL can be cleared. If after performing normal SI diagnostics and another root cause is not found, GM Engineering is aware of this concern and is working on a resolution.
Version
1
Modified
#16-NA-377: Service Emission System Message with DTC P206B Set/Stored - (Dec 20, 2016)
Subject: Service Emission System Message with DTC P206B Set/Stored
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Colorado
2017
2017
LWN
All
Cruze
2017
2017
LH7
All
Express
2017
2017
LWN
All
Silverado
2017
2017
L5P
All
GMC
Canyon
2017
2017
LWN
All
Savana
2017
2017
LWN
All
Sierra
2017
2017
L5P
All
Equipped with Diesel Engine (RPO L5P, LH7, or LWN)
Condition
Some customers may comment on a Service Emission System Message. This usually occurs after recently filling the DEF tank with the ignition in the on position, if:
•Using a mobile fill cart with an automatic nozzle
•Filling up at a commercial truck service station with DEF dispensing equipment
During diagnosis a technician may find DTC P206B set or stored in the history.
Note: Shortly after filling, the “Service Emission System” will clear on its own.
Cause
It has been found that some DEF fill equipment uses pumps that create a high level of temporary aeration of the DEF fluid being dispensed in the tank. This aeration of the DEF fluid could cause a temporary issue affecting the proper operation of the in-tank DEF Quality sensor. Seconds after a fill event completes the aeration dissipates and the DEF Quality sensor will return to its normal operation however if the customer has the vehicle keyed on during the fill event it is likely that this condition could occur.
Information
To reduce the likelihood of this issue occurring, the vehicle should be keyed off during filling of the DEF tank. In the event the condition is seen, the vehicle should remain keyed on until the “Service Emission System” warning clears. The P206B code in history can then be cleared. While not required some DEF filling equipment can be sold with an air/fluid separator, which can further reduce the likelihood of fluid aeration.
Version
2
Modified
Dec. 20, 2016 – Added Chevrolet Express, Colorado, Cruze and GMC Canyon, Savana models with additional RPOs LWN and LH7. The Note in the Condition has been updated.
#11 ·
#16-NA-380: Diagnostic Tip for Excessive Smoke From Tail Pipe, DTC P2002 Set - (Nov 16, 2016)
Subject: Diagnostic Tip for Excessive Smoke from Tail Pipe, DTC P2002 Set
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Express
2010
2017
Diesel Engine (LGH, LML, LUZ, LWN, L5P, LH7)
Colorado
2011
2017
Cruze
Silverado
GMC
Savana
2010
2017
Canyon
2011
2017
Sierra
Condition
Some customers may comment about excessive smoke coming from the tail pipe.
The Technician may find:
•DTC P2002 set.
•Cracked or broken Diesel Particulate Filter (DPF).
Correction
A properly functioning diesel particulate filter should remove most if not all soot particles from the exhaust stream. The following test should not be performed immediately after a regeneration because of the reduced filtration efficiency of the DPF without any soot in it.
The purpose of this test is to aid in diagnosing a DPF that has failed internally.
Service Procedure
Object ID: 4622615Click here for detailed picture of the image.
Note: Assistance may be required to perform exhaust soot flow test.
With assistance, the engine will need to rev to Wide Open Throttle 3 consecutive times while using a cheese cloth or equivalent, over the tail pipe.
•A failed DPF has excessive soot particulates on the cheese cloth or equivalent. Refer to the graphic.
•A DPF that is working properly should show no or very minimal signs of soot particulates.
If the DPF has been found to be the cause of the heavy soot. Replace the DPF. Refer to Exhaust Particulate Filter Replacement in SI.
If the DPF has been found not to be cause of the heavy soot, refer to SI for further diagnostic testing.
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
4050860
Use Published Labor Operation Time
Version
1
Modified
#12 ·
#17028: Customer Satisfaction Program - Diesel Owner Manual Supplement Missing - (Feb 9, 2017)
Subject: 17028 — Diesel Owner Manual Supplement Missing
Models: 2017 Chevrolet Silverado HD
2017 GMC Sierra HD
Reference Number: N162080400
Release Date: February 2017
Revision: 00
Attention:
This program is in effect until February 28, 2019.
Make
Model
Model Year
RPO
Description
From
To
Chevrolet
Silverado HD
2017
2017
L5P
6.6L diesel engine
GMC
Sierra HD
Involved vehicles are marked “open” on the Investigate Vehicle History screen in GM Global Warranty Management system. This site should always be checked to confirm vehicle involvement prior to beginning any required inspections and/or repairs.
Condition
Certain 2017 model year Chevrolet Silverado HD and GMC Sierra HD vehicles, equipped with 6.6L diesel engine (RPO L5P), may not have had the Diesel Engine Owner Manual Supplement and/or insert installed at the assembly plant.
Correction
Insert the Owner Manual Diesel Engine Supplement in the vehicle.
Parts Information
Quantity
Part Name
Part No.
1
English Language (U.S.) Owner Manual Diesel Engine Supplement
84290183 (US)
1
English Language (Canada) Owner Manual Diesel Engine Supplement
84290183_CA (Canada)
1 (If Required)
French Language (Canada) Owner Manual Diesel Engine Supplement (Must be ordered with Insert 84289451 below)
23476170_CA
(Canada)
1 (If Required)
French Language (Canada) Owner Manual Diesel Insert (Must be ordered with French language owner manual diesel engine supplement)
84289451
(Canada)
Note: The French language owner manual diesel engine Supplement (PN 23476170_CA) must be ordered with the French language owner manual diesel engine insert (PN 84289451).
USA: The owner manual diesel engine supplement is to be obtained from the GM 1Store through the GM Global Connect site. Be sure to request the appropriate owner manual diesel engine supplement part number.
Canada: The owner manual diesel engine supplement is to be obtained through GM Global Connect under App Centre, Business Office, DGN Online Store, or by calling DGN Customer Service at 1-800-668-5539.
French Language owner manual diesel engine supplements and inserts are to be obtained through GM Global Connect under App Centre, Business Office, DGN Online Store, or by calling DGN Customer Service at 1-800-668-5539. A VIN is required to complete the order.
Labor Code
Description
Labor Time
Trans. Type
Net Item
9102982
Install Owner Manual Diesel Engine Supplement
0.2
ZFAT
N/A
Service Procedure
Dealer Stock Units
Place the diesel engine owner manual supplement with the owner manual.
French Language Supplement (Canada Only)
 1. If a customer requests a French language diesel engine supplement, order both the owner manual diesel engine supplement and insert from DGN.
 2. Place the French Language diesel engine owner manual supplement and insert with the owner manual.
Dealer Responsibility
All new, used, GM Certified Used, courtesy transportation vehicles, dealer shuttle vehicles, etc. in dealers' possession and subject to this program must be held and inspected/repaired per the service procedure of this bulletin before customers take possession of these vehicles. Involved vehicles must be held and not delivered to customers, dealer-traded, released to auction, used for demonstration, or any other purpose.
All GM Certified Used vehicles currently in the dealers’ inventory within the Certified Pre-Owned Inventory System (CPOIS) will be de-certified and must be held and remedied per the service procedure in this bulletin. Upon submitting an accepted/paid warranty transaction in the Global Warranty Management (GWM) system, the vehicle can be re-certified for sale within the CPOIS system, or once again be used in the CTP program.
Dealers are to service all vehicles subject to this program at no charge to customers, regardless of mileage, age of vehicle, or ownership, through February 28, 2019. Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the involved vehicle listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. A copy of the customer letter is provided in this bulletin for your use in contacting customers. Program follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this program enters your vehicle inventory, or is in your facility for service through February 28, 2019, you must take the steps necessary to be sure the program correction has been made before selling or releasing the vehicle.
Dealer Reports
For dealers with involved vehicles, a listing with involved vehicles has been prepared and will be provided to U.S. and Canadian dealers through the GM GlobalConnect Recall Reports, or sent directly to export dealers. The listing may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this program is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this program.
Customer Notification
USA & Canada - General Motors will notify customers of this program on their vehicle and provide an English language Owner Manual Diesel Engine Supplement with the letter (see copy of customer letter included with this bulletin).
February 2017
This notice applies to your vehicle, VIN:_____________________________________
Dear General Motors Customer:
We have learned that your 2017 model year Chevrolet Silverado HD or GMC Sierra HD may not have had the Diesel Engine Owner Manual Supplement and/or insert installed at the assembly plant.
Your satisfaction with your Silverado HD or Sierra HD is very important to us, so we are announcing a program to fix this condition.
General Motors is providing you with the Diesel Engine Owner Manual Supplement. Please place the enclosed supplement in your vehicle with the owner manual for future reference.
If you have any questions or concerns that your dealer is unable to resolve, please contact the appropriate Customer Assistance Center at the number listed below.
Division
Number
Text Telephones (TTY)
Chevrolet
1-800-630-2438
1-800-833-2438
GMC
1–866–996–9463
1–800–462–8583
Puerto Rico – English
1-800-496-9992
Puerto Rico – Español
1-800-496-9993
Virgin Islands
1-800-496-9994
We sincerely regret any inconvenience or concern that this situation may cause you. We want you to know that we will do our best, throughout your ownership experience, to ensure that your GM vehicle provides you many miles of enjoyable driving.
Terry M. Inch
Executive Director
Global Connected Customer Experience
#13 · (Edited)
there also are bulletins on parts restrictions on fuel systems, nox sensors, turbos and all other parts related to the engine, those i will not post, they are just hoops for us to jump through, there is one bulletin that I removed the engineering name and number.
and also there are some of these issues they will not have a fix for MONTHS, like block heater on the 2.8l, don't expect a fix till fall of this year at the earliest, if not fall 2018. there is a ton of codes for these engines.
Reactions: John Lee Pettimore
#19 ·
Stronger than a Super Stuck Thread Sticky....it has it's own Forum.
:hairy
#21 ·
Thanks for pointing that out. I removed it.
Posted these in a rush was cooking supper and the wifes kids were not on the pc so took the opertunity to don't quickly. Stupid new password system..... slowed. Me down...
Sent from my SM-G903W using Tapatalk
#22 ·
thanks mebob. very informative
Sent from my SM-G920V using Tapatalk
#23 ·
No problem they just recalled 2 l5ps for incorrect pulleys. But didn't think I needed to post it
#25 ·
It's only 2 trucks they recalled one was stock one customer had. The idler pulleys they installed were in the wrong position or wrong one. I didn't read it because it's only 2 trucks I know I won't see one
Reactions: Dribeerfeht
#26 ·
#PIP5487: 2017 6.6L L5P Duramax Coolant Leaks - (Mar 16, 2017)
Subject: 2017 6.6L L5P Duramax Coolant Leaks
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Silverado
2017
All
All
6.6 L5P
All
GMC
Sierra
2017
All
All
6.6 L5P
All
North America
Additional RPO/s:
6.6 L5P
Condition
A customer may comment on a coolant leak, coolant consumption or of a low coolant message being displayed on the Driver's Information Center (DIC).
Cause
This may be due to cooling system leaks or an improper coolant fill procedure.
It may take a few engine temperature cycles (from operating temperature to cold) for the coolant level to show a lower than normal level.
Be sure to complete the current SI coolant system leak checks and verify there are no external leaks.
Reference the locations below to aid in locating external coolant leaks.
If no external leaks are found, refill the cooling system following SI procedures for filling the cooling system.
Evaluate coolant levels after a proper coolant fill is completed.
Correction
If the diagnosis has lead to external coolant leaks or a coolant loss concern check for leaks in the following areas:
Object ID: 4747691Click here for detailed picture of the image.
Object ID: 4750018Click here for detailed picture of the image.
Welded flange leaking on the Exhaust Gas Recirculation (EGR) coolant return pipe. Refer to call out #1 in the above picture.
Object ID: 4747685Click here for detailed picture of the image.
Welded flange leaking on the Exhaust Gas Recirculation (EGR) coolant feed pipe. Refer to call out #2 in the above picture.
Object ID: 4747686Click here for detailed picture of the image.
Another view of the leaking welded flange on the Exhaust Gas Recirculation (EGR) coolant feed pipe. Refer to call out #2 in the above picture.
Object ID: 4749115Click here for detailed picture of the image.
Coolant leak at the O-ring seal of the Exhaust Gas Recirculation (EGR) coolant feed pipe. Refer to call out #2 in the above picture.
Object ID: 4749101Click here for detailed picture of the image.
View of a rolled or pinched O-ring at Exhaust Gas Recirculation (EGR) coolant feed pipe. Refer to call out #2 in the above picture.
Note: The leak shown above could only be confirmed after removing the front accessory drive bracket and alternator.
Object ID: 4750082Click here for detailed picture of the image.
Coolant leaking from coolant hoses at the Emission Reduction Fluid Injector (DEF Injector).
Please be aware of the following if there is a need to pressure test the cooling system:
Note: The radiator surge tank uses two different radiator surge tank caps. The radiator surge tank cap that vents pressure in the event of excessive cooling system pressure is located on the lower outboard side of the radiator surge tank (2). The radiator surge tank cap that is located on top of the radiator surge tank (1) is where the cooling system is filled and where pressure testing equipment is to be mounted.
Caution: The cap mounted to the top of the surge tank uses LEFT HAND threads. Turn the cap clockwise to remove the cap or counter clockwise to install the cap. Failure to turn the cap in the proper direction when installing or removing it may cause damage to the cap and/or the surge tank.
Refer to Cooling System Leak Testing (L5P) for more information.
Version
1
Modified
there are pictures along with this but they do not matter for u guys, but new engine, new problems are starting to show, ive had one all ready with a fuel line leaking. as on drivers side which was stupid easy to fix, but I wanted to do the passengers and remove cooler:)
#90 ·
Where is the low coolant sensor? I get a "Low Coolant" message on the DIC after parking overnight in my driveway which is about a 4 degree slope. The message clears as soon as I get back on level ground. I checked the coolant level in the white surge tank and it looks good.
#28 ·
So far I've had 3 of these happen...most notably the "Chuggle" in 3rd gear, and the low coolant level message. I'm sure over time they'll figure it all out. Thanks for the info!
#29 ·
Yup its all part of a new platform. The lml luckly didn't give me to many cool leaks or engine issues. Was mainly emissions. But the l5p will be way different and we will go through weird issues for sure
Reactions: kev.milr2639
#30 ·
Great info.. THANKS!! I sub'd for updates to #PIP5480. Having that exact issue and took it to the dealer today, however it began regen as i pulled in the parking lot and they say they can't replicate the issue.
