1 - 10 of 10 Posts
On my way to work this am my truck slung a belt.. I instantly turned around and hauled it to the house.. I got a gates belt to replace the other one and when I went to install I noticed a bunch of belt debris tangled up on the tensioner pulley. I removed the assembly and behold
What would cause this to happen?
Reason I'm asking is 2 weeks ago I had my truck at the dealership for a recall.. While there i asked them to check a whinning noise coming from under the hood I hear when accelerating.. They told me my alternator was going bad.. It could last 3 days or years.. But wanted almost $900.00 to replace...which I would never pay...any how I'm trying to figure out if they miss diagnosed or is this a result of a failing alternator.. I agree with faulty tensioner.. But I'm a parts changer not a mechanic..
I had a loud whining noise on my LMM which I assumed was the alternator. In the process of taking it out, I spun the wheel on the tensioner and lo and behold it was a mess. I replaced it and the noise was gone.. Still have the original alternator in it to this day.
Discussion Starter #7
So glad you posted that!!! I swapped out the tensioner with a gates and put a new belt on.. Noise is gone!!! Hopefully it was just a bad "egg"
Whining noise you were hearing was likely the bearing in the tensioner.
Over the years I've had several of that style tensioner fail -- and not on pickup trucks....
Usually also destroys the belt.
(been a bunch of years since the last one; knock on wood)
So the dealer wanted you to pay $900 to replace a good part. Sheesh.
1 - 10 of 10 Posts
