1 - 13 of 13 Posts
Dudes and dudettes, I have a problem I really need to get fixed. I have an idea but need some help. I have a 2001 duramax. It runs great but when I want to pass or pick up speed I have power until the service light comes on and cuts the power. The truck will only rev to 2000rpm and run no faster than 65 or 70mph. When I turn it off and it sits for 30mins or more the light is off and it is fine until I want to push it hard. I think it is the EGR valve or the tank fuel pressure sensor. Whatchyall thank?
Does it cut down into underdrive or does it stay in overdrive?
When was the last time you changed the fuel filter.....thats where i would start!!!!!
Fill out your sig so we know what ya got yr, turner, ect...
I have a 6.6 2500hd.
Really......any upgrades???? You said you pulled the codes...you got a turner or did someone else do it??? if you got a turner what kind, what level you running it on???? is it completly stock!!!! The more you can tell us the more likely someone can help:drink
· Stupid Has The Balls
I have a 6.6
Not to bust your balls here but all DMaxs are, so all of us do to :rolleyes:
Fuel Pressure Release Valve might be the problem. The truck will go into a fuel starved limp mode if its malfunctioning. Look into a FPR Shim Kit. Real cheap, might fix it and if it doesn't, you only spent $20 to buy it and have it shipped to your door and it'll help in the future
1 - 13 of 13 Posts
