· Premium Member
Thinking about going to a larger set of tires/rims for the ole girl.Would it be a good idea to get larger rotors since I an going to add more weight to the system? I don't have a whole of experience in this area, but it just seems that it would be something to think about.
If you tow or drive the Blue Ridge, you will be thankful. Get slotted, not drilled. Cyro if you can afford them. Drilled might shatter under towing loads. Cyro treated last and are strong. Do check the rotors to make sure the metal to thickness is right. That middle air slot SHOULD NOT be wider than stock.
Oh, get heavy brake lines, not rubber.
