Ok, i know LB7s are prone to injector problems. So I try to keep my injectors "fresh". I usually try to add DieselKleen (White Bottle) to the tank, every other fill-up. Is their anything else I should know or do?
Wat? Is it a GURANTEE that the injectors will fail?i also use diesel kleen, that and clean fuel. the injectors will fail but keeping everything clean will help some.
I have gotten a little better fuel economy with AMSOIL additives as well I am running the Fuel Concentrate and the cetane booster in every tank.i use amsoil additive and i did notice a little diff in mpg and it runs smoother and quieter
I never measure it, I guess around 10 oz per tank.How much 2 stroke are you putting in a tank?
