Hello, I'm hoping someone here can help with the problem I am having.
I have a 2002 gmc sierra 2500 duramax zf6 truck. My injectors have been going bad for a while but it had still been drivable and only had a rough idle and a light haze. Now its throwing a cam sensor code p0341 and I have checked the reluctor wheel on the crank to make sure it's tight, checked the wiring, and replaced the cam sensor. It still has the same code. It's very hard to start and when it does it smokes whiteish gray. When I'm driving down the road it doesn't smoke but when I push the clutch in to drift to a stop it smokes white like crazy. If I coast to a stop in gear it doesn't smoke.
Has any body ever seen this?
Could bad injectors somehow cause it to throw this code?
Moved to LB7 for more help
