I have a 2001 stock it had p008& code it turned out to be rail sensor was unplugged I repaired that then I got P0087 and sometimes p0093 balance rates are good and 30000 miles on Bosch injectors dealer changed focus all lines on top engine fuel filter assembly I looked for soft lines didn’t find one idles 5000 psi when it goes into limp mode he fuel pressure drops to 11000 psi also put vacuum guage 2 to 3 idle goes to over and going down road 8” vacuum
It sure would be nice to make sentences out of your words. Makes it much easier for people to understand.
LB7 Duramax
I have 2001 GMC 3500 Duramax, The Truck went into limp mode The code was P0088. I repaired it, the problem was fuel rail sensor was unplugged while I had it apart. Also, I changed Fuel pressure regulator and fuel rail sensor from auto zone. After reassemble, it started setting code P0087. I have 30,000 miles on Bosch injectors and the FICM. Also, dealer changed all rubber lines on the top of the engine and fuel filter assembly.
