1 - 15 of 15 Posts
Hello everyone,
I wanted to get y'all's opinion on this setup. I have a stock 2002 LB7 that is due for injectors. I intend to replace them but I want to go with 30% over injectors. Would my stock components be able to handle these injectors. I also intend to get a FASS 165 lift pump to help with fuel filtration and fuel supply. Would I need to tune the truck after? I also plan to get a bigger turbo but in a couple of years. I am looking at Duramaxtuner's Stealth 64 and 67. Which one should I go with? I want that loud turbo whistle but I also want reliability and to keep my stock components. What do y'all think?
Thank you,
SGlll3
Hello everyone,
Thank you,
SGlll3
i think that this largely depends on what tune you have on the truck, who made it, and how heavy your right foot is.
you will need to tune the truck to run 30 overs or it will just smoke like crazy. (you may want to look at the SAC injectors since they are supposed to be more reliable). Any time you add power you increase the risk of things breaking.
You can do everything your wanting to do on a stock engine and it will run fine until it doesn't. If you are after reliability your going to need to spend the money to do the build right. That means an upgraded transmission is in your future, and things like headstuds are probably not a bad idea. Additionally, before adding power you should make sure the truck is 110% in perfect mechanical working order or your funds should go towards fixing problems first.
With reliability being the primary concern, you should either keep it stock, maybe add a lift pump and some other small stuff to improve injector life and reduce wear. Or you should do the injectors, since they are due, add a light tune so you dont dump diesel everywhere out the tail pipe, then build the trans, then do your turbo and other toys. Its important to balance the fun upgrades with the functional ones. Adding big injectors, a turbo, dual CP3's and the like is fun, but if you have a stock engine, stock rods, stock head bolts, your likely to run into problems at some point. To keep the reliability factor high you need to also upgrade the engine and transmission components as you add power.
generally speaking it is considered safe to add 50-100 horse power over stock without any major modifications to the truck, note, that upgraded injectors are NOT required for this level of power. So the gains you would be wanting based off the injector upgrade would require a built transmission at minimum. Yes you can run the truck with the 30 overs and a safe tune that wont break things, but if your buying 30 overs for power, thats probably not the direction you are looking to go.
The turbo won't really whistle much on the low end. The stock cp3 will pushit but I'd go with a stroker 12 would be best if your wanting to go big power down the road but a stock is fine with 30 over. I'm running a s366sxe with stock cp3 and sticks and I'm fine.
I don't understand " injectors are due".
If the truck is not puffing white smoke at idle it's pretty much a wast of $ to change them injectors.
The LB7 came stock with inadequate fuel filtration and that is why injectors were failing early. The best thing to do for your injectors if you haven't already done it is to get a catapiller fuel filter adapter and use the cat filter. Diesel fuel can be very dirty and the dirt particles in the fuel sand down the tip of the injector until they do not seal well anymore and start dripping fuel.
Save the huge expense of injectors and give your injectors clean fuel.
Former GM Tech and parts
Just because it isn't smoking doesn't mean the injectors are fine. There is a lot more to injector health than that.... Yes, filtration is a KEY element to keeping injectors happy, but that's not the only reason LB7 injectors went bad.
Hello everyone,
Thank you, SGlll3
Saying that your stock components can handle that setup is easy to do, but there are a lot of things that factor in to that. Tuning, driving habits, condition of engine parts and maintenance. But I would say yes as a general answer. I have a 2002 that I have been sled pulling with since 2012. My truck is set up with Fass 165, 60% injectors, LBZ cp3, and a Fleece 63mm Cheetah turbo. I competitively sled pulled up until the end of the 2017 season on a completely stock engine, with stock head bolts and gaskets. You have to realize, I was playing with fire-and I knew it. But I made it all that way on a stock engine with 266k miles.
I agree with @[email protected] with going with the SAC 45s. And yes, tuning after doing the larger injectors will let you get the full benefit of the injectors, even if you don't do the turbo for a while.
I have never run a Stealth, but I know a handful of people that have. Most of them had turbo issues pretty soon after install. They all have gone different directions with their setups. Either way you go, if you don't use your head and treat the truck sensibly after you have fueling and air flowing well, a 63/64/67mm charger is enough to hurt a stock engine if beat on the wrong way.
The upgraded stock filter in my opinion is as good or better than investing in a adapter and a cat filter, many have had problems with air leaking through the adapter and the ratings on the new stock filters is virtually the same as the cat filter.
If your wanting the whistle more then anything , I just put on a wcfab intake an horn an hsp cold an hot side tubes (which was free, givin to me by a friend) an believe me or not you hear the turbo 110% more, now looking at the price to actually buy all that I don’t know, it sounds good but that a chunk just for sounds. But I was amazed at the difference I won’t lie
the colors are off but free is free, an it’s not like people are looking at it while going down the road
Discussion Starter #12
Thank you everyone for your replies, they have really provided me with adequate information. I'm sorry Ive been so busy with graduating and school but anyways its summer now! I haven't done anything yet. My dad is still very hesitant to drop a big chunk of change into this 17 year old truck. But I intend to keep it for a long time, my dad bought it brand new in 2002 and I basically grew up in it. It has too much sentimental value to me to just sell it.
So, what happens if I just never replace them? What will eventually happen if I do not address the injector issue? I went to my local chevy dealer and the service department manager said to drive the truck with the injectors like that until it doesn't run anymore, which really made me till my head and look at him in weird way because I would think that would put additional wear on other components but, what do I know? He works for GM so he should know best. Also, is the blow by coming from underneath the truck and from lifting the oil cap caused by the bad injectors?
Thanks,
I have a 2002 2500hd 4x4 that I changed the injectors and turbo about 3000 miles ago, running Lincoln Diesel 45 over SAC injectors and 64mm turbo and mileage tune currently. 3" turbo exhaust down pipe with 3.5" inlet pipe and intake, Air Dog pump,PPE boost increase valve along with Banks big head waste gate valve and 4" exhaust. Turbo spools quickly and injectors made big power difference, fuel mileage is related to your right foot, but highway mileage at last 300 mile trip was 20.3. My suggestion is that if you have it pulled down for injectors I would do the turbo at the same time, you will need all the room you can get when pulling turbo. Had to custom bend up a long breaker bar with torch to get the exhaust bolts loose on turbo against fire wall, very tight, even had to use cheater bar on breaker bar. I also did injection pump fuel pressure regulator and related hoses, fuel and coolant, thermostats,along with doing valve adjustment. Good luck
Thanks,
Sure you can run it right until the last injector fails on it like he said, then you’ll be buying a whole new motor to drop in on it, I got my truck just the way you did basically and literally until parts are falling off while going down the road I’ll still keep it, save the money an do the right upkeeps on it an your kids will drive the truck
1 - 15 of 15 Posts
