1 - 2 of 2 Posts
Going to be going with Merchants injectors in the spring...Just trying to figure out if I'm going to do the install or if I will let him do it...
Its really not that hard to do.
But Eric Does great work too.
Yes Eric does do good work. I drop by his shop here and there.
There is a good write up on here in the DIY section. I don't know your skill level, so I can't say whether or not you can do it. I'd recommend that you read through the write up, decide whether or not you think you can do it, decide whether or not you have at least a full day to devote to it, decide whether or not you have a shop to do it in (I'm from NE Ohio so I know how cold it is there)... and balance that against the cost of having Eric do it for you... but then again, if Eric does it for you.... he'll stand behind it too.
I've looked through the write up and I know I can do it just would have to pick up the tools. Its more about the space for doing it since my dad took over the large garage. Truck isn't a daily driver either so not worried about that just would have to find a spot to work on it. Plus the warranty of him working on it would be great just encase something happened.
1 - 2 of 2 Posts
