I have a 2003 3500 lb7 as you can see in my profile picture currently at 119k miles not sure if ima need Injectors but it’s blowing heavy white bluish smoke when in idle no check engine light check oil dipstick no milky residue or in oil cap no milky white residue not sure if it’s the injectors or head gasket that’s causing the white bluish smoke but truck seems to run fine new to diesel engines never worked on them just trying to figure out if it’s injectors or head gasket which engine temp gauge never goes above the 1/4 line idk if LDS injectors are good or what you guys think
