Okay sorry if I'm not posting in the correct spot.
So I believe I'm having a maf problem but I'm not 100% sure why or if I am at all. From what I've read, maf reading at idle should read approximately 38 and around 400 at wot. My maf read 27 at idle and scales up to around 240 at wot. I am only able to reach about 17psi boost at wot. Obviously it would seem like I have an air problem. But I have no boost leaks(I've checked multiple times). I have a brand new 64mm super core turbo, 45over sac injectors with efi live tuning to go with it. Wastegate is set to 30psi and is functioning properly. I have tried a new maf and it reads the same. I have a spare ecm and with it installed I read the same thing. Truck is laggy at low rpms and smokes a lot when I get on it. Rail pressure commanded and actual read right next to eachother all the way up to 24k. Anybody have any clue as to where I should start looking? I've been chasing this for a long time.
