The stock injectors will hold together just fine I made 545hp 1165tq on my stock injectors. The LB7 injectors go bad though. You can't do anything to stop them from going bad also.i heard stock injectors wont hold together
U don't need to upgrade injectors u less u are doing a turbo upgrade, the stock turbo will run out of air long before the injectors will run out of fuel with a lift pumpso lly why is prob a better way to go?? then ill upgrade injectors along with lift pump 4 inch straight pipe with a down pipe air intake, efi live or what fpr programmers guages should i look for standard or automatic, if standard ill just upgrade the clutch to a b3 plate pressure plate system form south bend clutch ???
