Just bought this truck in it's current state and am at a bit of a loss. I am a tech but on european cars so the specifics of the duramax is all new.
The truck is a 2004 lb7 with 200k. Currently will crank but not start. The back story as told to me is truck was running fine. Turned it off to go for lunch and would not restart afterward. Original owner sold it like that to the person I got it from. Seems like he was just knowledgeable to get into trouble OR he found out what it needed and realized he was in over his head. I hope not the second choice. Was told the initial breakdown was 5 months ago so god knows what all has been done and tinkered with in that time.
My quick assement of the truck.
Oh and I have not tried starter fluid while cranking. I would assume the p/o did that and got nowhere. I am feeling like either a pump issue or an open injector are the culprits but would like some more seasoned input. TIA
Ken
- oil smells heavy of diesel and is filled to the top of the hatch markon the dipstick
- has 2 new batteries that are fully charged
- cranking speed seems right (may even be a bit fast) I am a bit concerned about compression but after 5 months of the p/o trying to start it I would think is may be washed out.
- primed the system with the hand pump (can feel pressure build in system when doing this)after cranking pressure is gone
- only fault in ecu was for glowplug curcuit (failed to right down the p code but cleared it and it has not returned)
- glowplug light comes on and seems to cycle as designed
- immobilizer light comes on during initial key turn and then turns out as I suspect it should. (my only concern here is the key I have is just a metal key. I am not sure if there is supposed to be a chip in these keys or not.)
- moved a/c comp. out of the way to access the cp3 pump to check for fuel flow. (with the feed line to the common rail T fitting removed and cranking the engine I get what I thinkis a VERY small about of fuel for such a "high pressure" system. The fuel exiting is clear and free of any air bubbles but only streams out in about a 1 1/2 inch geyser that I can easily but my finger over and restrict with very little resistance.) THIS SEEMS WRONG
- If that is normal what is the next step for me to take???
Ken
