Hi guys,
I’ve been dealing with an underpowered truck for a while now. Finally got an edge insight to see if I can figure out what the deal is. (Out towed by a 6.0 gas). It often seems like a safety mechanism when it happens. Pulling hard and then like I’ve rolled off the pedal. Like some computer nanny trying to keep me from speeding but it really hangs me at 40-50mph climbing hills.
Anyway, I am getting p1093. After some review on the site I see it could be a fuel pressure regulator, cp3, filter, blockage in the line, collapsing hoses, filter head, maybe more. Any advice on where to start?
I tested the balance rates with the edge. It shows 3.1 was the worst but that’s in spec if my research is right. I’ve recently changed the filter but this has been an issue for several years and I never realized the issue was as bad as it is until towing with dad who has a gas truck. I change that filter almost as regularly as the oil. I have recently changed the fuel lines between the filter head and the pump because I thought they were old and letting it lose prime. I can compare the desired fp and actual fp with the edge and it’s obvious where I lose power. Under 25% throttle the fp is pretty spot on with the desired. Any hard acceleration or towing though sees the desired at 23-24k and actual at 5.5k. Yesterday with my empty stock trailer I saw it get as low as 2.3 and I thought it was going to totally quit. I’ve seen the actual pressure reach 23k but that’s after letting out of the pedal and I’ve seen it as high as 18k when being a lot less aggressive with the pedal.
I don’t have a lift pump and this has been an issue for years. Occasionally I see an overboost code but that maybe unrelated. 270k miles on a what I think is a stock truck. I got it with a cai and magnaflow exhaust.
Where do I start or are we still missing data?
