Well the original problem was As titled ran my 2003 duramax out of fuel put several gallons in wasn't able to get it to fire sent to buddy to go and try to get it taken care of he says hes just used starting fluid got it to fire it screamed at red line for about 15 seconds even after the key was shut off. Claims there was a cloud of smoke when it shut off.
I know The risks of the using Either on a diesel. Figured my buddy did as well.
as far as the smoke I cannot tell you the color because he says it was too dark to tell when it happened.
I cannot get it to start ever since
It cranks over but seems to be struggling to do so unless I have the jump Box hooked up to it With a scan to I can monitor the real pressure says after cranking for a period of 10 or so seconds that it gets up to 17000+ PSI
Were do i start n ive bleed it till I get fuel to the rail ovwr and over still nothing.
Also there is a cel light that stays on. But no code.
I cant remember if that's normal till the trucks running or not.
Stock lb7 new (less than 10k injectors)
Dsp5 switch efi live tunes.
6' Straight pipe
6' Straight pipe
