1 - 9 of 9 Posts
anyone know if a lb7 twin kit will fit on a 05 lly with the lb7 ihi turbo on itits an s475 over stock turbo dunno if the piping will clear the egr junk
LLYs use a VVT if I'm not mistaken and the LB7 doesn't so idk if it would work right out of the box. Might need a lot of modifying
aready know they are two differnt turbos just wanting to know if the lb7 s475 over stocker twin kit will fit on a lly that has a lb7 waste gated turbo on it already fitment wise clearing the egr stuff
I believe where the air enters the engine is different.
Why not get a kit for An lly and tell the builder the turbo you have for it.
Im Superrrrr!
you would have to make your own piping...
Also 01 piping is different from 02-04....or so banks tells me with their kits.
Discussion Starter #6
because i got a free sdp twin kit for an lb7 just wanted to know if it would fit my lly since it already has an ihi stock lb7 turbo on it so it would hook up fine just not sure if it'd fit the lly has the egr still and pretty sure the y brige is differnt dunno if that matters. if not ill just buy another lb7:)
If you put an LB7 bridge in and take the egr out i believe it will work
I'm That Guy...
Call Scott.
Discussion Starter #9
Talk'd to scott he said pretty much the samething as GeorgiaDieselGTO.
1 - 9 of 9 Posts
