1 - 8 of 8 Posts
Okay so I have an 06 lbz I found out last week I have a boost leak guy at the shop gave me a price to fix it. But he mentioned the turbo could be bad!!
So what I was thinking is about getting another turbo in advance so I'm not in shock when he tells me it's bad. I found a stock turbo with a batmowheel already in it pretty cheap around $500..
Would it be worth it to just go ahead and get my hands on it while I can?? (Before it gets sold)
Discussion Starter · #2 ·
And on my up pipe the riser for the egr cooler is busted. And I got a boost leak where the boost tube is because of the egr delete so I was wondering how hard is it to do all the work myself and just get an exhaust shop to weld the riser on the up pipe
How do you know your turbo is bad. have you been getting codes?
I don't know yet. Until the shop looks at it but I been thinking about doing it myself? Any idea how hard it is to get to
Fix your boost & drive pressure leaks before you swap turbos. And the repairs aren't that bad.
yea i get what your saying how hard is it to remove and replace Ybridge and boost tube?? New to the duramax as you can tell
The y-bridge is kinda a pain but definitely not impossible. Boost tube is simple, 2 clamps. Do some searching here & you'll find step by step instructions to help you out
Okay man thanks what you think I should type in the search bar
1 - 8 of 8 Posts
