1 - 11 of 11 Posts
2016 Chevy LML 2500 4x4 bone stock CCLB summit white, air ride on board air, b&w gneck hitch
My buddy bent his driveshaft the other day tryin to pull his deuce and a half. He wants to know what type of driveline to replace it with. His has the same upgrades as me, pretty much same truck as me. Any input is appreciated. He has a heavy right foot also. :gearjamin
Discussion Starter · #2 ·
Bump
I would personally say consult a local shop and have a steel unit made. Should be pretty cheap.
Kinda hoping newtomegmc chimes in as it's his area of expertise and has helped quite a bit of us better understand the dynamics of what to do and not do when it comes to drive shafts.
That would b nice if he would chime n. But steel is the way to go?
Steel is the way to go if cost is of any factor to you... lol
Cost is not a factor. Sry. Shoulda put that n the OP
Bump
Wouldn't a good set of traction bars fix the problem?
Hit up a local driveshaft shop and ask the owner for their opinion. My suggestion would be to look into chromoly or a non-hollow heavy wall aluminum
Ok sounds good rescue man
R u sayin reactions bars would prevent the problem from happening again? Oleblacky
Yes, I meant put a stock drive shaft back in and then put you some traction bars on. Performance is awesome with the bars on + just knowing your taking the pressure off everything else.
1 - 11 of 11 Posts
