Recently I've been having to add coolant to the recovery tank, about a 1/4" per day, so I pulled the passenger side fender liner and observed leak evidence on the front and rear lower corners of the passenger side head just below cylinders #1 & #7. I've been reading every post I can find regarding coolant leaks and will inspect and replace the three turbo coolant supply & return hoses located above hoping that the leak is just dropping down to the lowest points on the head. Truck is stock with the exception of a Kennedy lift pump, only 118k miles, what many would most likely call a "grandpa truck." No bubbles in the recovery tank at idle and the upper radiator hose is soft when the engine is cold. For those of you with experience with blown head gaskets are the attached photo's indicative of a typical head gasket leak or is it more typical of a leak coming from one of the smaller hoses above?
