I was driving my 04.5 LLY home from work last month and it went BOOM! I'm pretty sure it sucked in a valve and I will pull the motor apart soon to confirm. Since I didn't want my truck in 100 pieces for any length of time I ended up buying an LBZ from a local JY to prep for a weekend swap. I plan to use the LBZ block, heads, flywheel and balancer with the LLY reluctor wheel/crank sensor/timing cover, injectors, wiring, turbo, cp3....
The LLY injectors fit the LBZ heads without a problem unlike the glow plugs. I have to use LBZ glow plugs in the LBZ head.
my questions:
If I want to keep a stock tune do I need an LBZ glow plug module?
If I don't want to keep a stock tune, can EFI live reprogram the LLY glow plug module to work?
Thanks in advance.
-Rob
my questions:
Thanks in advance.
-Rob
