dont know what its from but i was told it was normal for an lbz however its not normal for anything to leak oil so hopefully someone has seen this before whats going on? it looks like the hose that runs to the intercooler on the pass side its blowing all over the bottom side of my hood on that side also the second pic is above the pass tire with the inner fender out
Uploaded with ImageShack.us
and through the pass. side wheel well
That oil is most likely cause from the PCV system, it dumps oil fumes in the turbo, and the oil accumulates in the Innercooler. The boots and clamps on the innercooler are not a perfect seal, so some oil is pushed out under turbo pressure.
Many just reroute the PCV system, so the oil fumes are dumped under the truck. No more problems and the engine stays much cleaner.
is there a fix??....popping the hood and seeing oil everywhere drives me nuts
Yep- just reroute the PCV system, so the oil fumes are dumped under the truck. No more problems, and the engine stays much cleaner. Many vendors have a kit to do this.
You should also inspect the boost hoses for holes or leaks, and retorque the clamps.
I moved this, it is not a 911 problem.
oh ok thanks and sorry ab that!!
