1 - 11 of 11 Posts
I am tearing into my 2007 Classic right now to investigate the P0299 code.
Been reading up on this forum about fixes for this DTC. I see alot of people report that there are 2 O-rings that deteriorate over time and could be one of the causes. Seems likely since my truck is all stock except for a CAI and it has @347k miles on it, I so decided to take a look at mine.
When I got started everything seemed tight as could be and there is a ton of grease / grime on everything. I have it blown apart right now and these O-rings seem to be in good shape. Other than cleaning everything up good and reassembling with no trouble found there - is there something else that I should investigate while I am in here?
Thanks in advance members!
Discussion Starter · #2 ·
Got it all put back together and cleared the code. Went for a ride and CEL came back on. This time it is P2563. Did a little more research and decided to clean the Vane Position Sensor with my fingers crossed that this fixes it and I am not looking at a turbo replacement.
It was pretty dirty. I cleaned it up with some brake cleaner and noticed that it was a little scored on the tip. Not sure if that is the problem or not so I put it back in. I am going on a test drive and will report back.
Drive it about 30 miles yesterday afternoon with one cold start / 3 warm starts and a combination of city traffic driving and a couple WOT pulls up to 80mph pulling down the I-40 on ramp. No codes thrown yet.
Make sure MAF and MAP are clean. Other than that, you may have had a compromised induction connection that you repaired by taking it apart and putting it back together.
Thanks for the suggestion.
I cleaned both of those 3 weeks ago with MAF cleaner when I first got the P0299. When it came back a few days later, I decided to check out the O-rings.
Drove another 25 miles so far today and no CEL.
Well damn.
I also had to prime the fuel filter after parking it overnight on a fairly steep upgrade with the front higher than the rear. I could hearing hissing and see fuel dripping from the water sensor on the bottom of the filter as I pumped it. I have a new Baldwin fuel filter and an OEM sensor in the toolbox that I plan to swap in at the next oil change.
After running for @30 seconds the P2563 code came back.
Don't think those are related, but thought I would mention it.
If you have fuel dripping OUT, under vacuum the same place will probably leak vacuum IN. At least you knew where to fix the problem
Every since changing out the fuel filter last week and putting the "Stock with options" tune back in it I have not gotten any of the CEL / DTCs that I was getting regularly.
I was running the "Economy" tune with my Banks Automind handheld before.
Could these really be related to P0299, P003A and P2563? IDK.......
Reactions: cfell
I'm a bit confused if the tune or me cleaning up stuff made the difference, but I have 530 miles in varying driving / loaded conditions with no CEL.
I also hand calculated that I had a MPG improvement. 13.3 -> 14.5
Filled up again last night and hand calculated my milage.
440.1 miles
26.9 gallons
16.3 mpg
This entire tank I purposely drove only back roads and kept my speeds under 65mph. Definitely had a difference.
1 - 11 of 11 Posts
