1 - 13 of 13 Posts
Hello all , i havent posted in a while but i need some possibilities,
when pulling boat down interstate 75 mph/ 2000 rpm about every 30 seconds the exhaust sound changes, EGTs go up and it puffs smoke for a second then goes back to normal(clean). no rpm change, but speed drops a little?
I was thinking maybe my torque converter is finally taking a #$%^, except i would think there would be an rpm change because of slippage?
got edge CTS set on level 2.
Got any ideas?
Hot Rod Photographer
Egr?
Slave to the Interwebs
I would check the vane position sensor
X2 on vane position sensor. Its the sensor on top of turbo. Not hard to change but pretty pricey.
Sent from my SPH-D700 using AutoGuide App
You should check for codes first-- might have a code stored.
Hang it!...Fire!
yea dude set your edge to monitor vane position and watch to see it go up and down
Heres a pic of where it would be.
i have a used one if it ends up being the problem. Gm wants 600$ if i remeber for a new one. So pm after u check for codes if u r interested.
Discussion Starter #8
Discussion Starter #9
Discussion Starter #10
could it be possibly i need a lift pump?
this truck only has 58,000 miles on it!
how would i go about checking for proper operation?
Monitor it with your edge. You may also have a problem with the edge if you are not throwing any codes. If I remember right you can fool with the vane position with the C/S. Set your monitor to watch the vane position, take it for a drive. At 2000rpm you should be running about 45 to 50% open.
Discussion Starter #12
ok, i will give it a try, i guess i need to call edge and ask them why it isnt throwing a code!
Anynews? I dont recall it throwing a code on it eithier though
1 - 13 of 13 Posts
