1 - 15 of 15 Posts
Would an LBZ turbo work on my LLY?
Could i just drop it in and go or would i need custom tuning?
Are all the mounting locations the same?
It would bolt right in. Don't see to many guys from San Diego on here
Haha you definitely dont see too many people from sd in here. What part of san diego are you in?
Would the LBZ vane position sensor and vane control solenoid work on the LLY?
I'm in Santee. what part are you in? I got my old LBZ Turbo we can match up If you want?
why ? lbz will spool quicker but but the lly turbo will flow more, so why go through the trouble of replacing a stocker with a stocker?
Cuz i need a new turbo and i found a good deal on an lbz turbo.
Im up in poway, but i go down to santee/lakeside area alot.
PM'd you my number
yes it will work the diufference in the vane sensor is the connector their is an adapter. wen i got my new vane sensor from gm for my lly it is actualy for 04 to i forget what i think 10. and they gave me the adapter to make it work on my lly
Banned
It requires the adaptor, I put my old LMM turbo on my buddies LLY. Runs like a champ. I have an adaptor if you need one.
Awesome! Thanks drzsz and smokinlmm for the info!
And smokinlmm, pm me how much you would want for that adapter.
When my LLY turbo crapped out I ran my buddies stock LMM turbo for about 6 months. Bolted right on, no special tuning, no adapters. I just re-used my LLY vane position sensor
I would do that but my stock vane position sensor is bad also
Freakk hit me up i got that adapter from doin my 4094vnt swap
Not likely that both the turbo and VPS would go bad at the same time, it's usually one or the other. I'd hate for you to go through the trouble of changing the turbo if not necessary
1 - 15 of 15 Posts
