1 - 15 of 15 Posts
I'm leaking oil from passenger side pretty bad leak. Can't see from top I'm almost halfway down on dipstick any ideas?
is it definatly the passenger side? get a flashlight and see if you can see any oil in the valley (under the turbo). if there is i'd say oil return from the turbo, if not then its probably a lower valve cover gasket
I didn't see any but there might be. It's pretty bad oilly under there from it. And yea def passenger side looks like it be right under fuel filter area maybe
id say the lower valve cover gasket is leaking. not too many other places mid engine area that would leak.
Is there anymore thing that could be on passenger side
not that i can think of. have you crawled under the truck and looked at the oil pan?
Oil pan is dry
im leaning towards the valve cover gasket man. im not too sure what else on the pass side could be leaking oil. someone else will chime in that knows more
Idk I hope someone wil chime in
I can tomorrow it dark here. There's a little oil around pcv filter but dint look like be enough for this amount and crank case o ring seal looking thing
I tore into it today. Had a torn o ring is were most of die was coming from were crank shaft seal was I think
Discussion Starter · #14 ·
Well I thought it was the o ring bc it was torn went for a few drives looked up under it and it stil had more oil don't think it's residule oil. Idk what else to do
Discussion Starter · #15 ·
Could it be rear main seal
1 - 15 of 15 Posts
