1 - 8 of 8 Posts
My fuel return line is dripping where it transitions from hard lines to braided lines and into the cooler. Both of the fittings are pretty rusted.
Is there a quick fix?
Do they sell just the braided lines?
I'm stranded at work.
Discussion Starter · #2 ·
Alright,
I cut off the fuel hard return lines and cut off the quick disconnects
Used 5/16" hose and hose clamps.
Will it's hold? I'll take pics
I would think it would temporarily until you could get a new cooler put on it. You could also bypass the the cooler with a section of hose and a couple barbed fittings for a quick get it home fix.
I know a few northerners that had to temp. bypass theirs because of rusting parts.
Nice temp job, could always put an extra clamp on for security sake.
PS: damn thats a dirty cooler:D
Yeaahhh......she's a little dirty and rusty lol
The leak was actually a Pinhole in the hard line that runs back from the cooler to the tank.
And I did put 2 hose clamps on the cooler - tank line ends!
The fuel lines are very low to NO pressure, because that is un-used engine fuel returning back into the fuel tank.
Moved to LB7
i thought crap didnt rust in the south?? anyways, what you did will work for a while. the quick connects you cut out serve no purpose than a quick easy way for the factory to build the truck. up here in ny, where rust is everywhere, i make new fittings that go into the cooler. i have a hydraulic flaring kit that has die's to make the flared ends it needs. then i run plastic fuel line and plastic quick connect fittings. never rusts out again! if the customer doesnt wanna buck up for that repair, i make the same stub lines out of the cooler but put a slight bubble flare on the end to help hold the rubber hose i clamp on.
1 - 8 of 8 Posts
