1 - 2 of 2 Posts
Hey guys.. I am a pretty new to the duramax family... I got a 2014 LML that seems to be seeping a bit of coolant out the water and that being the top rad hose is pretty stiff. Should i be concerned it also has a head gasket issue or could the water pump be causing the stiff rad hose??
It's supposed to be hard when it's running.
Sit overnight to cool, then check it for firm. But if you're WP is leaking, any pressure is going to leak off.
1 - 2 of 2 Posts
