leveling a 06 3500 dually
2 reading
1.9K views 1 reply 2 participants last post by  NorCalTruck_com
I know this has been ask before, want to level the front of my 06 GMC 4x4 3500hd dually flat bed. what is the best way to do it.?
There are a few ways to level a 2500/3500, but if not done correctly you will have ride quality issues. If done correctly (Staying within the designed working area), ride quality will not be bad. The correct way, would be to use an Upper Control arm that allows for more down travel, combined with the correct length shocks to allow full range of the added travel. Some trucks sit 3.5-4" higher in the rear than the front, If your truck is like this, You might want to think about a 4" kit to level. Factory specs, angles, and alignment will be much better in that situation. Below is a link to our leveling packages by "Stage", and our 4/6" packages as well. There is detailed info at the links to help, or you can ring our sales staff with questions at the number below.
NCT Leveling packages
https://norcaltruck.com/chevy-gm-2500-3500-2001-2007/2in-3in-leveling-packages/
NCT 4-6" packages
https://norcaltruck.com/chevy-gm-2500-3500-2001-2007/4in-6in-lift-packages/
