1 - 8 of 8 Posts
· Im Superrrrr!
the brackets are the shock extenders...when you crank the torsion bars you will need a longer shock or the extenders if you plan on using stock height shocks.
The only things you will really need to install it yourself is the torsion bar unloading tool.
I bought one for like 40 bucks on ebay....looks a strangely shaped clamp.
A hammer and something skinny to knock loose thetorsion bars cause more than likely they will have some rust on them.
a couple smaller sockets and some PB blaster or WD40
· Premium Member
A local shop is putting on my keys and installing new shocks (Which I already have) for $75.00. I'm just dropping off my truck before work and I will pick it up before lunch. Much easier if your crushed for time.
should i use the new shock mounts with my kit or buy new taller ones
Seeing how rough the stock shocks ride you would be happier if you bought new ones. I'm a big fan of skyjacker nitro shocks and bilisteins are great too from what i hear. If you are on a budget use the extension mounts you have now with the stock ones. But if you want a better ride get new, longer ones:rockin
Not to jump into the thread but I'm doin the same thing. I would like to get a set of bilsteins is there a certain size or model number to get for the level kit 2-3" lift? And all they around?
· Premium Member
Check out Norcaltruck.com. He is a sponsor here and will hook you up. His screen name here is NorCal Nick.
1 - 8 of 8 Posts
