1 - 20 of 27 Posts
I have efi goin in next Monday trying to find a lift pump to get me through. I'm thinking of the ppe or raptor? Any advice
I like my raptor alot and people have had great luck with the airdogs Also.
- Adam
Will the stock fuel filter housing be ok with raptor
Airdog!! And remove the factory filter! That's my 2 cents
Air dog 2 or just air dog??
Do you change draw straw with raptor or air dog
When I bought mine the only option was the plain air dog.. I went with the light to tell ya when to change the filter although it's never came on and I still change it so I dunno if it even works.. But anyways I'm pretty sure mine is a plain air dog (150) gph I think that number maybe way off it's been on there bout 3 years now. I just recently pulled the factory filter off and bypassed it and I'm pleased!
or you can just go balls out if its an LB7 and do the ADII (easier install w/ quick disconnects) and put a nicktane adapter on there with a CAT filter
injectors are costly :D
and on the ADII there is no need to drop the tank or mess with the draw straw... :thumb
See that woulda been nice I had to drop the tank and cut the filler tube all that jazz
Administrator
AD2....
Filtration and air removal is good for LB7 injectors IMO.
AirDog II 165 on an LB7 truck hands down. You want to get the most life out of those precious injectors as much as you can, and that = filtration.
Discussion Starter · #16 ·
What is a nictane kit and CAT filter
google nicktane
its an adapter for the stock FF unit to allow a CAT filter to install to it.
higher filtration, lower price per filter = better for your injectors and your wallet
oh and CAT filters are the ones of the CAT line of heavy equip
Discussion Starter · #18 ·
Do you need the whole kit for around 300
Discussion Starter · #20 ·
That link won't work
1 - 20 of 27 Posts
