My truck is a 2005 lly and it randomly just wouldn’t start. Truck ran fine 5mins before and when I tried to start it, it just cranks. Fuel filters are good and it has prime. Codes are p0522 p0642. Truck also flash low oil pressure on the dash. I don’t know what’s causing this and the local mechanic doesn’t either
LHN...We ARE the Joneses
I don't know what's causing this and the local mechanic doesn't either
Did the tech inspect the oil pressure sensor or the harness to it?
Hookem knows his stuff. You have a wire rubbed through somewhere on the oil pressure circuit.
I will look into that and see. How would that keep the truck from running though? any common areas i should check? I have already looked near the alternator. Also if this matters, the truck just recently had a water pump job.
Truck also flash low oil pressure on the dash.....How would that keep the truck from running though?
One of the many Safeguards to keep from damaging the engine?
