I've got a good one so the silverado 05 2500hd duromax won't run with the ficm bolts connected to bracket however when I remove the bolts it runs but it's in limp home mode where it won't go over 40 or 50 miles an hour and cuts out under acceleration. When I push on the ficm unit while the truck is running it will die. Any help would be appreciated,if the ficm edu unit was bad the truck wouldn't run at all i figure but I'm a new Duramax owner so I'm still getting familiar with the vehicle
Discussion Starter · #2 ·
So I did an experiment and when I have the ficm mounted as it should with the insulators and vibration washers and bolted down it won't start, when I remove the bolts and the bottom corner of ficm makes contact with the mating surface of the ficm bracket it runs but poorly so now I'm thinking it's a grounding issue or wire short cuz it only seems to run when the ficm unit is touching the metal of the bracket and I thought that's why the insulator and rubber vibration washers were there for,The wiring harness looks wrapped up nicely by the alternator so i haven't looked for harness wire rub yet but thats probably happening tomorrow just to be sure,Does Anyone know the grounding points for the ficm unit or had this problembefore? hmmmmm
Then something in the ficm is shorting to the case.
I ran a groundwire from ficm case bolt to a ground bolt and its running better but still throwing out a dtc u1500 which is network serial bus(communication wire) plus an abs module and hvac module, Today i ran a engine to frame ground and cleaned some other grounding points,So you think the ficm is toast? From the other posts I read though the ficm is All or nothing either it runs or doesn't run it all
