My truck just randomly decided to not start, it ran fine and I shut it off to go into a restaurant and when I came back out it would crank but not start. multiple cel's and the oil pressure warning came on, on the dash. codes are P0522 P0642
And yes I have checked my fuel filters and re primed the fuel system
You say you re primed it, was there air in it? If so that’s a good place to start
No there was no air in the fuel. I also have a fass pump so im certain its getting fuel
Yeah you should be good there then. Do you have access to a scanner that can read rail pressure and the like? With no codes it’s hard to chase it without being able to view engine data
P0522 engine oil pressure circuit low voltage
DTC P0642 5-Volt Reference 1 Circuit Low Voltage for Crankshaft Sensor
Looks to me like you may have a circuit problem/ECM problem tied to your engine oil pressure sensor. Maybe a problem with the crank sensor/circuit also
