Hello all, New to the site. Whats the difference between the LLY and the LBZ??? Which one is better?
R racng69 · Registered Joined Feb 23, 2010 · 64 Posts Discussion Starter · #1 · Feb 27, 2010 Only show this user Hello all, New to the site. Whats the difference between the LLY and the LBZ??? Which one is better?
ahduramax · Premium Member Joined Nov 28, 2009 · 3,771 Posts #2 · Feb 27, 2010 Only show this user Lbz!!!!!!!!!!!!!!!!!!!
daddysLBZ · VAGITARIAN :) Joined Mar 31, 2008 · 8,062 Posts #3 · Feb 27, 2010 Only show this user no brainer .........LBZ rules,ask anyone on that,welcome to the forum!
Vandy5 · Premium Member Joined Feb 10, 2009 · 370 Posts #4 · Feb 27, 2010 Only show this user welcome to df. lbz is the way to go more hp/tq from factory no overheat problems
R racng69 · Registered Joined Feb 23, 2010 · 64 Posts Discussion Starter · #5 · Feb 27, 2010 Only show this user ok so how do you know which one you have?
R racng69 · Registered Joined Feb 23, 2010 · 64 Posts Discussion Starter · #6 · Feb 27, 2010 Only show this user Ok so my 8th digit is "2" so i have an LLY
boccheballs · Registered Joined Oct 29, 2008 · 1,322 Posts #7 · Feb 27, 2010 Only show this user The Lbz Has A Revised Piston Design To Lower Compression Ratio To 16.8:1 From 17.5:1, A Stronger Block And A 32-bit Ecu. Quoted From Diesel Power
boccheballs · Registered Joined Oct 29, 2008 · 1,322 Posts #8 · Feb 27, 2010 Only show this user What Year Because The 06 Lly Is A Detuned Lbz I Believe
R racng69 · Registered Joined Feb 23, 2010 · 64 Posts Discussion Starter · #9 · Feb 27, 2010 Only show this user mine is a 2005
boccheballs · Registered Joined Oct 29, 2008 · 1,322 Posts #10 · Feb 27, 2010 Only show this user You Have A Great Motor. Get An Exhaust, Lbz Mouth Piece And Efi Live And That Truck Will Be/do Everything You Want.
