LM2 Oil Filter - ACDelco PF66, K&N, or PPE High-Efficiency LM2 Oil Filter
1 reading
17K views 9 replies 10 participants last post by  JG Wentworth
Hi LM2 owners, after my first oil change I switched over to Amsoil's Synthetic Diesel Oil SAE 0W-20 and a K&N filter and have been very happy so far, but I just recently came across this PPE High-Efficiency LM2 Oil Filter (Part#114000650) and this guy makes a pretty compelling argument in this video -->
Is anyone using this filter in their LM2 that could elaborate more on the subject? Specifically:
  1. Is it worth it?
  2. Do you believe it helps provide more engine protection than OEM or K&N?
  3. This oil filter is much longer than OEM, how much more oil is needed if using this product?
  4. Could you post a picture to how far this oil filter extends past the frame of the undercarriage?
Any additional information would be greatly appreciated.
AC Delco Oil Filter (Part# PF66) $8.99
K&N Oil Filter (Part# HP-1021) $14.99
PPE High-Efficiency LM2 Oil Filter (Part#114000650) $26.99
3.0L Duramax Lifetime Oil Filter (Part# PP8451-X) $279.97 🤯
I purchased 2 PPE filters from Rudy’s Diesel (no affiliation) they were the cheapest after shipping. I plan to do an oil analysis with the stock filter and oil at 5k (15k total miles). Then may go to mobil 1 dexos D spec. Course the dealer does free OC for 48k, just never liked anyone touching my rigs but me. May just let them do the OC with the AC Delco and use this PPE filter and see if my numbers improve vs stock filter. IDK.
Im a big fan of using Oil analysis to get your OC interval dialed in then run with it. Everyones commute or driving habits are very different.
I have always been an ac delco fan, but was disappointed with the duramax oil filters i recently purchased. Ordered 2 from rock auto and when taking out of box one of the filters had a rattle. I then noticed a small "ding" on the rounded edge/bottom of filter. You could wiggle the filter element with your finger.
I of course did not use that filter but cut it open with my filter cutter (used for my race car) and that ding caused the spring sheet metal piece that holds the bypass valve and keeps pressure on the element to be dislocated. In addition the filter pleats were widely spaced and the internals just had a cheap feel vs other filters I have cut apart such as Bosch (which are one of my favorites). Even the house brand orielly filters are often made by wix and are better quality. The Bosch also uses a real spring vs a bent piece of sheet metal to hold pressure on the element.
I am sure the acdelco meets oem specs and will work just fine, but I will not be purchasing anymore until their quality goes back up.
On a side note, Rock Auto refunded the damaged filter no questions asked.
Sent from my SM-G965U using Tapatalk
