The reason I ask is that since I bought my truck, the sound under acceleration has gone up. I’ve heard it described as a roar...mine is very similar. Not so bad in the morning but much louder when warmed up. I need to check the clamps since I’ve also heard that they can be loose from the factory. Too damned cold to do that now so it’ll have to wait.
I have noticed the same issue..it appears due to the extreme cold..and the fuel combination the engine is not getting the cetane as smoothly as needed
These insights might help..
Quotes
Winterized diesel fuel
Winterized diesel fuel is a combination of #1 and #2 fuels that, when blended together, holds a higher concentration of #1 grade diesel fuel. These fuels are used during the months when it becomes too cold to use #2 grade.
The combination of both grades of fuel should contain enough energy components and lubricant properties to reduce the chance of the chemical mix gelling in colder temperatures. Typically, the fuel economy drops slightly during the winter months because the demand for it is less than at other times of the year.
Using #1 grade diesel fuel in the winter should never cause any immediate concerns. However, prolonged use in engines that are specifically-designed for #2 grade may reduce engine life span over a long period of time. #1 and #2 grade fuels can be mixed at the same time. This means you don’t have to worry if #1 grade is only available during the winter months.
What is the difference between Diesel Fuel Supplement +Cetane Boost and Diesel Kleen +Cetane Boost?
Diesel Fuel Supplement +Cetane Boost (in the white bottle) is a winterizer/antigel for use when temperatures drop below 30°F. for winter operability. Diesel Kleen +Cetane Boost (in the silver bottle) is an injector cleaner and performance improver for use when temperatures are above 30°F. Use our seasonal tip to help remember which product to use: “White for winter, silver for summer.”
I have used both Standyne and Diesel Kleen and have "smoother" shifts and quieter engine with Diesel Kleen. I will never run this engine without either..it becomes too harsh
Nice Ohio Weather..
