1 - 20 of 30 Posts
so why would my egts run up to as high as 2600 deg. i know thats not healthy
no i would not even leave my foot on the pedal long enough to see 2000 wow wow wow ur melting stuff
only did it once i dont even run hot cause of that
its never did it untill yesterday it did it once and i put it on no power haha
what can you do to lower your egts
u mean u dont run hot tunes?
what do u have and have done
i just got the tuner and pipe week before last, i updated my mini max the other day and ran hott and thats what it done so i went to no power tune just dpf delete
im thinkin mabe the pyro we put in messed up or something cause theres no way it should have read that hot and still run fine...its post turbo too
where di u mount it ? the gauge ? and u can lower egts by
downpipe
intake
intercooler
meth/water injection but im not a fan
i'm shocked if you actually it 2600 and didn't have any problems....
I knew that H&S's chit ran hot, but damn it boy
:l
X2
yea buddy
it didnt do it when i firts put it on there, im using the pyro and gauge on the h&s but yea i let off and chilled out for a while right when it done it. i wasnt even on the gas like i just stomped on it and it did that so i let up immediately.something isnt right tho. its before the turbo not after. im calling h&s today
keep us posted on what they say, i'm curious.
anything over 1500 is not good do some of the stuff i said to change it
wow wow wow. you see 1750?? that's insane. i heard the H&S on the new trucks ran hot, but if i knew it ran that hot it wouldn't touch my truck
EDIT: why would you tow heavy on a wild tune?? that's asking for all sorts of trouble- tranny, egt's, etc.
tow on stock or very close to it
at 14000 lbs ......yeah man lose that bs programmer
get a downpipe
or intercooler
or ppe manifolds and up pipes
or water/meth
I always run my truck this hard. I use wild because it's giving me the best fuel economy. I'll only keep it till 90,000 then trade it in on another. This is my second one this year. First one only lasted 5 months till it had too many miles. If I blow it up before that I'll coast it into a tree.
The new LML will run up to 1800 degrees if held WOT for extended periods on a Hot tune. If you are seeing over 2000, you have a pyrometer problem. Probably the PCH board that the pyro hooks in to. Give our tech department a call to see if they can help you diagnose any issues. 888-628-1730
You guys that are scared of 1700 degrees, this is normal for these new trucks when tuned. We have hundreds of dyno runs on the LML, 6.7L Cummins, 6.7L Ford, and 6.4L Ford that we purposely hold them at over 1800 degrees to test the durability. NO failures at our facility to date.
Many have this misconception that anything over around 1300 degrees is doing damage, not true. A stock truck will run these temperatures under the right conditions. With more power comes more heat, fact. EGT readings are a great reference point to start diagnosis for problems, or to see the range your motor is running in. Personally I believe that too much focus is aimed at EGT readings. There are a number of equally important factors that come into play, and a simple EGT reading alone tells next to nothing when other parameters of the engine operation are unknown. Just a little food for thought!
1 - 20 of 30 Posts
