Simple enough question..I've searched, but can't find confirmation.
From the sticky, I understand 285/70R17 is an alternative tire size for LB7, but I don't see specs on the LB7 17" wheel.
Can anyone confirm that a 17" LMM wheel (17" x 7.5 wide, 28mm offset) is compatible with the LB7?
Thanks in advance!
Carl
FWIW-I've been running H2s 17x8.5, 18mm offset) with 285/70R17 and no issues. Want to run same on LMM wheels. [Was running slightly worn BFG-ATs 315/70R17s with minor rubbing at rear on driver's side with bar slightly cranked and liner zip-tied).
That should not give you any problems. The bolt pattern changed on 2011+ trucks.
Rims will fit just fine, I ran a set on my 2002 for a while. Had 285 tires on it as well, did have to raise the front just a bit to clear.
Thanks for the help!
I'm getting ready to sell the truck and want to sell the H2s separately, because I'll probably get more out of the deal.
Regards
