I am wondering what gains can be had from an aftermarket fuel pickup in the tank? I am currently at the 600rwhp range with my filterless Fass 150 with the stock pickup in the tank. Just wondering if it is worth making the change.
If yes, what is the easiest install and best to avoid the 1/4 tank issue?
Paul
saw what you did there
If you're at 600whp right now, I don't see much gain from switching.
I need to update my sig. MPI Twins and 40 over sticks. Command and actual are pretty close, and I am holding 9psi WOT prefilter...not sure what the pressure drop is accross the filter.
