1 - 8 of 8 Posts
Im sured this has been asked befor but i cant find the thread but what is the absolute largest tire i could stuff under a 08 lmm dually 4x4 with a leveling kit and spacer in rear
I can clear 235/85/16's just fine on a stock 02 dually, no lift, leveling kit or nothing
Im thinking 285/70/17 or even a 285/75/17
That would be a 32.8 or a 33.8????
Without adding spacers in the rear, I have done 235/80R17s. Leaves about .5" between the tires. I don't like to get much tighter than that. Chance of heat buildup and blowouts if tires are touching. But if you want to run a 1.5" or 2" spacer between your duals, you could easily do 285/70R17 with some cranking, trimming, etc on the front.
with those 1.5 spacers... out studs are long enough or do they come with longer ones?
They bolt on and have there own studs on them.
That's why it seems like a sketchey idea because know the weight rides on the studs of the spacer
1 - 8 of 8 Posts
