1 - 9 of 9 Posts
· needing more money
Check the fuse. On my LB7 the horn would go out all the time. There was a short somewhere that no one could find for years. I'd just replace the fuse and go again.
Checked the fuse (there is only one?) Seemed good but swapped it anyway. No change. Thank you though.
Anybody know exactly where the horns are? Looks like I may be changing one out. Do they make more powerful stock replacements? I want train horns of course but can't justify spending the money right now.
i believe they are still in the same location
bump
I replaced both of my factory horns with crappy auto store replacements after I filled em with water and they stopped working. There is one on each side. They are behind the headlights and down a bit. Go in front of the inner fender wells to get to them. Easiest to lay down and look up to get to them once you figure out exactly where they are.
On a side note, F the dealer. They wanted $45 each for replacements.
thanks for the info
1 - 9 of 9 Posts
