:help Well I had a guy call me saying his lmm is using 2 qts or so of oil every oil change (5k miles). Its all stock, with 160k miles I believe. What do you all think I should look at first? I think I'll pull the intercooler boots and see how much oil is in the intake, then maybe pull the turbo mouth piece so I can get to the compressor wheel to see how much play it has. I will see if I can talk him into a pcv reroute and then put a catch can on it to see how much oil he's losing out of that. Anyway I have never messed with an lmm other than installing tunes. I'm going to try to talk him into deleting the egr and deleting the dpf also. Am I missing anything else to check? Thanks
Is he towing with it all the time?
I ran into this same issue about a year ago with my LMM. It never used oil at all, but when I took a good trip to the mountains and put her to work, I started to use oil. I tossed the question out to the forum here and got some good response. Sounds like GM has a bullitin out that says it is normal to use 1 qt of oil to every 100 gallons of fuel consumed. I never had this issue till I started working it over the mountains. I ended up using 2 qts over the entire trip of 4,000 miles in two weeks, but pumped just over 300 gallons of fuel. And since then it only uses oil when I'm towing heavy.
Might something as easy as this. Here is my original thread from last year..
http://www.duramaxforum.com/forum/towing-hauling/434010-question-those-tow-steep-grades.html
Update- Pulled turbo mouth piece and there was zero shaft play. The mouth piece was saturated from the pcv. I did a pcv reroute and egr blocker plate for him and also installed a single tow tune.
