Adding more hp will result in more regens, depending on your states emission testing you might be limited on what you can do.
Eventually the DPF will have to be replaced, doing the PCV reroute will cut down on the oily sooty build up in the EGR.
I did the reroute at 15k and kept the egr functioning until about 40k then I blocked it. At 56k I deleted the egr using the Sinister kit and the egr had very little soot buildup with no oily film just soot.
For longevity it would be best to delete both, if you legally can.
There are some people that ran the full emissions crap for many miles with no problems, but there are even more that eventually had problems and deleted.
If your thinking about deleting stuff in the future you might consider going with EFI tuning, then if you make changes you can get your tunes adjusted to your needs.
Edge does not offer emissions deleting with their tuners.
