Should I go with a load range D or E tire? If i ever pull anything it's seldom. Is there a big mileage difference between the 2?
It is stamped on the side of the tire. Some won't say D or E, but they will give a number of plys. 8 ply = D 10 ply = Ehow do you find the load rating for any given tire?
It varies from tire to tire. Some D rated tires can carry more weight than an E rated tire.Ok, just noticed on the website for my tire, they are rated D. I was thinking they were 8-ply. what is the normal weight for this rating?
I have put 12-13000 lb bobcat on the back with no issues. maybe I should have been more concerned.
Just because a tire has a greater load rating does not always mean a rougher ride. All the load or ply rating means is that the tire can handle a higher AIR pressure. Consequently, it can carry more weight for that reason when inflated to those higher pressures.I'll just go with a D. I know our trucks probably came with E ratings from factory, but I don't want the rougher ride if I don't need it.
