1 - 11 of 11 Posts
Just got my efi from idaho rob, and got 2 tunes from him and a dsp5. My question is if someone sends me a tune how do i load it onto the dsp5? And also theres supposed to be 5 diff. tunes on the dsp5, but it only shows 4 programs to cal. wheres the 5th? Thanks in advance.
The way mine works from my tuner is simple.
You take your stock tune, apply the DSP5 OS
Save the file and close it.
Re-open the the stock file with DSP5 program
Make sure its in Imperial
Run his DSP5 script
Save the file.
Do a full ECM reflash
Enjoy
if it only shows 4 on efilive than you still have 5...they don't count your base tune IRC...tune 1-4 are the actually modded tunes...
That's correct. The base tune is actually counted as 1.
So, DSP1= 2
DSP2=3
DSP3=4
and DSP4=5
ya i just checked...Where it says DSP Program #1 is actually the 2 tune on the dsp5...#1 is your stock...heres a picture to show you:
Discussion Starter #7
Thanks that answers one of my questions, anyone know how to do the other one, or do u have to look off the one was sent and put in everything that was modified into one of ur programs? (still learning)
Discussion Starter #10
I think you need to take another look.
DSP 4=1
DSP3=2
DSP2=3
DSP1=4
Base tune=5
Maybe mines weird but thats what it is
It all depends on which way you wire your switch...mine is like that too...but on the EFILIVE Tune page, its just like i had mentioned...now i can go back and change the two wires in the ecm to change the direction of the tunes on the switch...but its not that big of a deal to me...alls i care is where my powers at when i need it!
1 - 11 of 11 Posts
